Digital I/O
need help about a dll with panel function
I try to create a DLL file with a graphical panel, and i want to use it on an other platform with visual c++ compiler.
to release this DLL, i use an UI and generate a code with the option : Tools\UI to Code Converter.
now i have a code which can create a user interface without the file .uir
During the compilation there is no error, but when i want to test/execute it on Visual C++, I have an error message : The memory cannot be read, address 0x00000000.
Someone can help me about this? and if you want my project to see the code, i can give it.
thanks.
Message 1 of 1
(3,760 Views)
