Digital I/O
output cRIO timer
Hi everybody,
I'm new with labVIEW but I need help to accelerate my studying progress to make one system, I've done, working.
I'm working with a cRIO and some AI and DI/O modules.
1) I have an analog signal input, an AI, that when it is below a fixed value, let's say for example 6, it will give a signal to a DO that makes the start for a pump.
2) My problem is that: when the pump starts, it must run not continuously but every let's say 20 seconds for 40 seconds.
3) When the signal from the AI is over the value of 6, the pump must stop.
I did a .vi that works fine with cRIO and AI, DI/O modules for the points 1) and 3). My problem is the point 2) if the pump starts I don't know how to make it "timered-looped" and to stop it when it has to stop (from the AI, signal beyond the fixed value)
I hope to have been clear.
Thank you very much for your help
(5,415 Views)
Can you share some code?  There are many ways to do this.  Figuring out which way would work best for your exact situation needs a little more context.
(5,411 Views)
Hi crossrulz,
thanks for replying me.
here the .vi I built, before inserting the timer, or a rough idea of it, the .vi worked easy, now I have problem..
(5,406 Views)
Accepted by Frechete
It looks like you are really close.  I would not put the time check inside of a case structure.  Instead, make the timer reset when the AI is not more than 6.  Make the timer set for 40 seconds with an autoreset.  This will reset the timer after the 40ms.  Just add a little bit more logic for when your outputs are on and I think you will be there.
(5,395 Views)
