Digital I/O
pci-dio32hs pattern generation on linux
Hello!
I am a student at Padua University and I'm writing an application for linux using PCI-DIO-32HS.
I need to generate a train of bits at the maximum speed PCI-DIO-32HS can do (20MHz).
Do you know any linux driver supporting pattern generation?
Bastianello Simone
(3,421 Views)
Simone,
I suggest you take a look at the COMEDI web page.
Here you will find a list of all the HW that is supported by this Driver distribution for Linux. The DIO-32-HS board is in the list.
AlessioD
(3,417 Views)
Thank you for your reply.
I tried comedi, but I can't go faster than 200-300 kHz.
I tried also this code: http://www.ni.com/zip/daq/us/ni6533.zip , with the same results.
I need at least 10MHz
(3,407 Views)
