Digital I/O
power supply for 6519
Does this seem like a reasonable power supply to use for the digial output (sink) signals for the PCI-6519 board?
http://www.gwinstek.com/en/product/productdetail.aspx?pid=38&mid=52&id=126
I will be powering four 24v 1 watt solenoids (little guys).
Jason
(4,684 Views)
Accepted by UFlewis
Probably a little overkill for 24V solenoids, especially when you really only need ~5 watts...
http://www.digikey.com/product-detail/en/FSC-S5-24U/102-1575-ND/1699039
Unless there's some reason you need the programmability beyond what you can do with the DAQ, I see no reason to spend $500+ on a programmable PSU.
(4,680 Views)
Thanks for the link!  Much better option.
Jason
(4,672 Views)
