Digital I/O
read multiple analog inputs at the same time
Now tried to do as the document via 1 Daq Assistant  but still not working. (Example simple queue) Any Ideas? with this?
Message 11 of 14
(3,248 Views)
Chairat,
Please use your own thread. You hijacked this one about coding DAQmx with c++ and you are just confusing things. Not a very polite way to post.
Message 12 of 14
(3,243 Views)
Hongkun,
Look at the help for the DAQmxCreateAIVoltageChan function to see how to configure diff or rse. You can also configure this in MAX.
Message 13 of 14
(3,237 Views)
Accepted by Hongkun
Thank you for your reply! It is very helpful! I have checked the DAQmxCreateAIVoltageChan function and learn how to set the correct configuration. So I think I have solved completely my analog input problem.
To sum up:
1, you need to read in multiple analog input lines at the same time in one single task (e.g. set the line address to Dev1/ai0:1)
2, configure the channel to the correct mode in the DAQmxCreateAIVoltageChan, such as DAQmx_Val_RSE or DAQmx_Val_Diff. Be careful, in the example code "Acq-IntClk" installed with the drive, this mode is set to "DAQmx_Val_Cfg_Default", which means the default mode is used. I strongly adviced not using this mode unless you are sure what is actually going on. Personally I find the result is changing every time even I measure the same constant signal.
3, set the correct size of the data array into which  you want to put the acquired data. For example, you are reading 2 lines, each line you want 100 samples, then set this array to data[200] otherwise a buffer error will show up.
Hope this can help the others!
Message 14 of 14
(3,229 Views)
