Digital I/O
serial command syntax
Dear all,
I'm trying to comunicate with a device via a serial port. For this sake, I'm using the "Advanced Serial Write and Read.vi" from the examples library. I put the right prameters but I still can't figure out the right syntax for the srting filed to be written on the serial port. I always get a timeout error message.
Could you please give me an exemple of a command (string) to send to the serial port.
Please find in the attachement the protocol data sheet.
Thanks for your help.
(3,492 Views)
Please delete this read cause I've already posted here and in an another bord.
Sorry for the inconvenience
(3,484 Views)
I fixed the pb thanks
(3,478 Views)
