Dear all,
I'm trying to comunicate with a device via a serial port. For this sake, I'm using the "Advanced Serial Write and Read.vi" from the examples library. I put the right prameters but I still can't figure out the right syntax for the srting filed to be written on the serial port. I always get a timeout error message.
Could you please give me an exemple of a command (string) to send to the serial port.
Please find in the attachement the protocol data sheet.
Thanks for your help.
