10-05-2006 03:30 PM
10-06-2006
06:45 PM
- last edited on
05-28-2024
01:17 PM
by
Content Cleaner
10-09-2006 01:14 PM
Hi Daniel,
Thanks for the references. That is the board I am using. I am drawing the schematic right now to post it here. It is just a basic circuit that it was completely hand wired. I will get back to you in soon.
Leo.
10-09-2006 01:45 PM
Hi Daniel,
This is the circuit I am trying to use. I didnt have SW2 before. Now I am trying to read a total of 50 points using the burst handshake mode. My idea is to activate REQ1 (pin 2) using SW2 and then see the collected data (all same value) from the word long port 0 (I left DIOB disconnected intentionally). I expect to be able to change port A value (using SW1) and always read port B as zeroes (according to documentation). I have a test point to monitor the ACK1 signal. There is no power supply I am using the board's 5V line. All resistors are 10K.
If you need anything else let me know but I believe that all I can do now is provide you my code (based on the examples for burst handshake (DIsingleBufBurstHandshake653x.VBP). I am using VB5 and I dont have Measurement Studio.
Thanks for your assistance,
10-09-2006 06:02 PM
