Digital I/O
some help please?
can not configure my clock. there is always an error in the CTR group config.
(2,991 Views)
You are getting a CTR group config error, because you are using a counter example on a DIO card.
The counter cards and DIO cards use different chipsets, and so the VIs need to make different calls to the chips on the boards.
Use a DIO example and you will be able to configure the clock.
Regards
James
NI UK
(2,991 Views)
