Digital I/O
to control the voltage can we use usb-6001?
where can i find the usb-6001's software and driver?
(5,604 Views)
Accepted by topic author aydin
You can certainly use a 6001 to control voltage.... within the device's specifications.
Driver is part of DAQmx, available here: http://www.ni.com/download/ni-daqmx-14.1/4953/en/
(5,574 Views)
(5,573 Views)
actually I want to use 6001 to increase voltage from 1-5 input to 200-300 output, Is there any guide for this use?
(5,504 Views)
Hi aydin,
What do you mean increase from 1-5 to 200-300? Do you mean having an output of 200-300 V?
If that is what you mean, it will not be possible, the output range of the device is ±10 V, you can take a look at the device specifications.
http://www.ni.com/pdf/manuals/374369a.pdf
If this is not what you meant, then please elaborate more your questions.
Carolina
(5,462 Views)
Sounds like you need a voltage multiplier.
GCentral
(5,459 Views)
Thanks a lot.
you are right, I want to control a PZT with accurate steps of voltage(from 1v to 200v), to do this I need a voltage multiplier and I have to control it by computer program. but I dont know how can I use the 6001 or other products?
(5,444 Views)
