Thanks Justin,
I tried with the above method, i am getting all the bytes successfully. Again redifining the problem, in real time application, I am getting 16 bit digital data every 5 microsecond before which I get a DVALID signal which is active low. DVALID signifies the presence of this 16 bit data. Now I am producing some different pattern using the internal clock option using 6534 card. I am connecting REQ signal from this 6534 card to REQ line of IInd 6534 card. In IInd card I am defining I/O connector option in the Start vi which means that whenever REQ signal goes low, it will read data pattern. But adopting this method, when I run write data vi, my pc reboots. Also I am missing certain bytes in between.
Pl. help.
Nirmal Sharma
Enginner
Autotec Systems Pvt. Ltd.
Bangalore INDIA
