05-16-2006 09:16 AM
05-16-2006 11:08 AM
11-26-2007 12:18 PM - edited 11-26-2007 12:19 PM
I would like to bump up this old topic, because I am also having trouble simulating a 4072, in my case a PXI-4072.
Under INI drivers in MAX, I'm seeing the nisDMM items under Simulation, but when I try to Create New... NI-DAQmx Simulated Device... none of the DMM's are in the list of devices to select.
Mark S. said "NI DMMs do not support DAQmx simulation" ?, and then goes on to describe that it can be simulated in IVI. So, I'm a bit confused.
Richard
11-26-2007 02:04 PM
11-26-2007 02:32 PM
Thanks Marcos.
Yes, I tried that, with bad results - it said the device didn't exist. (I don't think it had "Model:4072" number in it, so I'll try again). Also, I'm not sure what to do with the PXI Slot setting (i.e. the resource name) because if it's a Simulated device, don't you still have to give it a slot number?
Also, what does that string look like sans emotocon? (
I'll keep plugging away, thanks.
11-26-2007 03:28 PM
11-26-2007 05:06 PM
08-01-2009 08:33 AM
08-01-2009 08:48 AM
Have you read the entire thread? You do not have the ability to simulate an NI DMM with DAQmx. You program an NI DMM with the NI-DMM software. If you want to simulate the DMM, then you have to use IVI. You also need to have the IVI compliance package installed. That, I believe, comes on the NI-DMM driver CD that came with the instrument. You can also download both from the Support link above.
Once you have the correct software installed, opne MAX and right click on IVI. The help will walk you through the process.
08-01-2009 01:16 PM
My original problem started with a PCI 6221 and 6229 not any DMMs, and I noticed it for all the simulated devices I can create in MAX. I'm guessing my problem is not exactly the same as Steve's although I have the same error message.
