Digital Multimeters (DMMs) and Precision DC Sources
HP 34970A problem with RS232
I want to control a HP34970A so i tested it with the Vi given in exemple by labview. I configurated the baud rate, parity on the DMM. I try to send "*IDN?" with labview but i have an error: "-1073807202" i don't know why.
could you help me. thank you
Luc (france)
(12,953 Views)
Bonjour,
Jetez un oeil aux liens suivants dans un premier temps.
On se recontacte si le problème persiste...
http://forums.ni.com/ni/board/message?board.id=140&message.id=5889&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=140&message.id=9815&requireLogin=False
Cordialement
David D.
Ingénieur d'Applications
NI France
(12,946 Views)
I have worked with a couple of HP/ Agilent equipment, including 34401A/ 34970A/ 36XXA etc. and this is one of the information you might wanna see.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(12,808 Views)
Bonjour,
Cordialement
David D.
NI France
Hello, i'm a student and i have a problem with the synchronisation between my computer and Hp 34790a, I dont know how to do it, i just tried to put the rights parameter in the exemple Vi of the drivers and it worked only once. the communication is make by the serial port.
Please, if somebody would have a manual or something that can help me i'll be so glad.
Thank you.
ratalanza@gmail.com
(12,480 Views)
If you would post your VI here, we can help take a look at your VI first.
Best regards
Ian F
依恩与LabVIEW
(12,474 Views)
Hi Marcolux,
If you want have the data simultaneous between PC and HP-34970, it's not possible because GPIB bus is not a very fast for this.
But you have web page, that explain how use Synchronous functions and Asynchronous functions for GPIB interface. It's a software capabilities, and it is important that our driver be capable of synchronous as well as asynchronous transfers. By having the ability to transfer data asynchronously, the instrument control application can devote PC processor time to other tasks. For example, an application can have two simultaneous loops, one responsible for the GPIB transfers and one that can perform other analysis or user interface tasks.
https://www.ni.com/en/support/documentation/supplemental/18/choosing-between-synchronous-and-asynchr...
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(12,453 Views)
@Luc,
try to communicate through another program e.g. "hyperterminal" or if you have the VISA software installed use the "VISA Interactive Control". That's the fastest way to check, if the configuration is done correctly. Once this is working you can continue with LabVIEW.
@MarcoLux
that sounds to me like data collision. Are you shure that the LabVIEW communication is really "serial" in the meaning of send query then waiting for reply before sending next time? Sending a query before receiving the complete data leads to a "collaps". A synchronisation between program and a serial connected device should not be so difficult as long you keep a proper serial sequence in your program.
Ciao,
Olli
(12,259 Views)
