Digital Multimeters (DMMs) and Precision DC Sources
Hi current measurement
In the KB Document ID 44BJPPBE that published, I measure the current at 1A and switch back to measure low current (10mA) what is the accuracy that i should get? Can help is it is a general practise to do that?
(7,541 Views)
Thanks for posting on the NI Discussion Forums!  I understand you want to calculate the accuracy of your current measurement.  The method you use to do this will depend on what device you have.  A great resource is the NI Digital Multimeters Help.  Make sure you have NI-DMM driver installed.  Go to Start»All Programs»National Instruments»NI-DMM»Documentation»NI Digital Multimeters Help.  Once you have this open, go to Fundamentals»Measurement Quality»Accuracy.  If you have any further questions after reviewing the documentation, please post back.
Rod T.
(7,526 Views)
Thanks for the info.
I wonder if i switch the measurement from 2A in (10S) to 1mA how long do i have to wait for the measurement to reach the accuracy range ?
(7,496 Views)
This will also depend on what DMM you are using.  The specification of interest is Settling Time.  Here is an excerpt from the NI-DMM Help file.
"Settling time is the time required for a measurement system to stabilize to a specified accuracy limit."
You can read more about settling time in the NI-DMM Help File.  Go to Fundamentals»Measurement Considerations»Settling Time.
Rod T.
(7,485 Views)
