Digital Multimeters (DMMs) and Precision DC Sources
How can I tell what version of NI-DMM I have?
I looked at the device drivers in MAX, but it does not give versin number. Is there a way to tell. I don't want to go through the pain (and sometimes risky) process of updating if I don't have to.
(6,770 Views)
It is possible to see the device driver version in MAX. Click once on the "NI-DMM" driver listing under the "Software" heading to highlight it. When it is highlighted, the version of the driver will be shown in the right-hand window of MAX.
Another method to determine the version of your driver is to find its listing under Add or Remove Programs (Start >> Control Panel >> Add or Remove Programs). Depending on the versions of your National Instruments drivers, the NI-DMM driver will either be listed in the main window or under the "National Instruments Software" listing in the main window. The version number of the driver will follow immediately after its name.
I hope this helps!
Sonya W.
National Instrument
s
(6,770 Views)
