Digital Multimeters (DMMs) and Precision DC Sources
I want to know the serial number of my NI4071
(7,761 Views)
If you want the serial number, check the white lable on the device. It normally says part number and serial  number.
Caroline Edenholm
Applications Engineer, National Instruments
(7,753 Views)
If the DMM is installed you can also see the serial number by looking in MAX.  Just select the device and look at the Attributes tab.
Otherwise the serial number will also be located on a sticker on the board.  It will be a string of letters and numbers below a barcode.
Brian P.
(7,743 Views)
