Digital Multimeters (DMMs) and Precision DC Sources
IVI based VB-Examples
configuring IVI-devices in vb-examples p.e. "codefreedmm", i get error BFFA002E while the CVI examples with the same IVI-devices work correctly.
Also the "INSTR" Examples p.e. "Measure DC Volts" don't work with VB, while they work with CVI.
My customer wants to use VB.
What do i have to reinstall?
(8,150 Views)
do you use Measurement Studio?
As far as I know the Examples and if I read trough the readmeDMM.html you can find under Start--Programms--National Instruments--NI-DMM I think you have to use Measurement Studio to run this examples.
But you can try the examples that ships with the newest NI-DMM, if you really want something to reinstall. Smiley Very Happy
Here you can also read the readmeDMM.
Hope this helps a bit.
Alex
(8,127 Views)
Hi Alex, thanks for your response, but I have to be more precise:
I do have the total developper suite installed on my computer, but:
The LABVIEW examples work perfekt with the IVI- drivers,  the CVI- examples do it as well,
but: the VB examples do not!
Checking the configuration always shows the error message mentioned above. (BFFA002E )
So meanwhile I have a slight guess, that VB is not as much supported as LABVIEW resp. CVI.
Do you have any idea?
(8,114 Views)
