Digital Multimeters (DMMs) and Precision DC Sources
pxi-4071digitizer function
How would I verify the digitizer function of the PXI-4071 ?
Dan
(8,107 Views)
If I understand your question correctly, you are interested in testing your PXI-4071 in digitizer mode.
For this we have some examples already built that will help you get started. Here is a link to the DMM Flex (Digitizer) Mode User Defined Step example.
Good luck,
Tica
(8,098 Views)
Hi Dan,
I forgot to mentioned that another way you can find examples for DMM is through the LabVIEW Example finder located under Help>>Find Examples. Here you can browse to Hardware Input and Output>>Modular Instruments>>NI-DMM(Digital Multimeters).
Tica
(8,088 Views)
Hi Tica,
I tried to follow the instructions in the example. Not sure how I would locate the Flex Mode DMM.vi in step 2.
Dan
(8,080 Views)
Never mind. I got it
(8,073 Views)
