Digital Multimeters (DMMs) and Precision DC Sources
Keithley 197A, making it work
Writing a program for a Keithley 197A DMM using LabVIEW 5.0 (comm. via GPIB, OS=Win95).
The problem is that, when using the officicial Keithley software it works, but when copying this to my application it doesn't. What goes wrong here? Some settings of LabVIEW?
When saving a modified Keithley program it also works OK. When copying everything to a new file, it doesn't.
Anybody got an idea?
(6,891 Views)
I assume you are using the Instrument driver contributed by Keithley. By copying everything into new file, are you referring to copying everything in the block diagram of the working VI and pasting it into the block diagram of another VI? (all the front panel terminals will be copied automatically) If that is indeed what you are doing, then the resultant VI should operate exactly like the original VI. If that is not working, let me know what error you are getting.
(6,891 Views)
