Digital Multimeters (DMMs) and Precision DC Sources
NI 4350 Trouble
I have a NI 4350 USB device with a TC-2190 thermocouple reader and I can't figure out how to use it with LabVIEW 8.6. It is recognized and works in MAX so is there simply a driver that I missed or have I missed the boat?
(9,388 Views)
Hi boz.wayne,
In order to use the USB 4350 High Precision Temperature Logger, you will need the NI-435X driver.  The manual is also a great reference.  After installing the 435X driver, there will be examples that install for LabVIEW.  You can find these examples by navigating to Start»All Programs»National Instruments»NI-435X»Examples»LabVIEW.  You can use these examples to get started with LabVIEW.  Please let me know if this helps out.
Best,
Adam
Academic Product Manager
National Intruments
(9,379 Views)
That did it, thank you very much.
(9,336 Views)
 I have trouble with NI 4351 card. I can see it make a temperature measurement in Max but noneof the VI's I downloaded work with Labview 2010. Please advice.
(8,719 Views)
First check to see that the instrument driver for the 435x downloaded to the correct location. You should see a folder labeled ni435x in C » Program Files » National Instruments » LabVIEW 2010 » instr.lib. If not, I would download the driver and move the folder to the correct location. You will need to verify the driver compatibility with your operating system.
Jake H | Product Manager
(8,698 Views)
I have a NI USB 4350 card. My system is xp. The driver I installed was NI435X252. I can test the ni card in nidaqmx and it is ok. Now I want to use visual c++ for the collection. But there seems to be a problem with my driver installation. I can not find " Start program »All Programs»National Instruments» ni-435x"
(4,881 Views)
