06-24-2010 05:18 PM
I have a NI 4350 USB device with a TC-2190 thermocouple reader and I can't figure out how to use it with LabVIEW 8.6. It is recognized and works in MAX so is there simply a driver that I missed or have I missed the boat?
		06-25-2010
		09:37 AM
 - last edited on
		12-30-2024
		05:21 PM
 by
			Content Cleaner
Hi boz.wayne,
In order to use the USB 4350 High Precision Temperature Logger, you will need the NI-435X driver. The manual is also a great reference. After installing the 435X driver, there will be examples that install for LabVIEW. You can find these examples by navigating to Start»All Programs»National Instruments»NI-435X»Examples»LabVIEW. You can use these examples to get started with LabVIEW. Please let me know if this helps out.
Best,
06-28-2010 09:08 AM
That did it, thank you very much.
08-05-2011 09:43 AM
I have trouble with NI 4351 card. I can see it make a temperature measurement in Max but noneof the VI's I downloaded work with Labview 2010. Please advice.
08-08-2011 10:05 AM
First check to see that the instrument driver for the 435x downloaded to the correct location. You should see a folder labeled ni435x in C » Program Files » National Instruments » LabVIEW 2010 » instr.lib. If not, I would download the driver and move the folder to the correct location. You will need to verify the driver compatibility with your operating system.
07-12-2018 10:04 PM
I have a NI USB 4350 card. My system is xp. The driver I installed was NI435X252. I can test the ni card in nidaqmx and it is ok. Now I want to use visual c++ for the collection. But there seems to be a problem with my driver installation. I can not find " Start program »All Programs»National Instruments» ni-435x"
