Digital Multimeters (DMMs) and Precision DC Sources
NaN
I have a PXI4071 DMM.  When I use the DAQmX vis (shipped w LV 8.5) and measure an open resistance I get "NaN".  When I use the "DMM Soft Front Panel" I get "OVLD".  Is it safe to assume NaN is the same as OVLD or an open or infinte??
(6,965 Views)
Hi Mr. Eastwood,
The NI Digital Multimeters Help (June 2009) is a great resource for messages. In searching for "NaN" you'll find a page called "Overrange/Underrange" that states that for the 407x resistance measurements, "Above 105%, NI-DMM returns NaN".
For "OVLD" you're referred to the "DMM Soft Front Panel" page with the following note: "If the front panel displays OVLD, an overrange condition has occurred. If the front panel displays UNDRNG, an underrange condition has occurred."
I hope that helps!
Mark E.
Precision DC Product Support Engineer
(6,961 Views)
