Digital Multimeters (DMMs) and Precision DC Sources
NaN
I have a PXI4071 DMM.  When I use the DAQmX vis (shipped w LV 8.5) and measure an open resistance I get "NaN".  When I use the "DMM Soft Front Panel" I get "OVLD".  Is it safe to assume NaN is the same as OVLD or an open or infinte??
(7,253 Views)
Hi Mr. Eastwood,
The NI Digital Multimeters Help is a great resource for messages. In searching for "NaN" you'll find a page called "Overrange/Underrange" that states that for the 407x resistance measurements, "Above 105%, NI-DMM returns NaN".
For "OVLD" you're referred to the "DMM Soft Front Panel" page with the following note: "If the front panel displays OVLD, an overrange condition has occurred. If the front panel displays UNDRNG, an underrange condition has occurred."
I hope that helps!
Mark E.
Precision DC Product Support Engineer
(7,249 Views)
