Digital Multimeters (DMMs) and Precision DC Sources
PXI 4060 "unknown device" but correct drivers loaded - probably broken card?
This is probably more general than just DMMs, but - I have the correct driver loaded for my PXI 4060 DMM.  Windows gives the yellow unknown device warning, but shows the PCI ID info (VEN_1093, etc.) and NI-DMM can't find it.  I have tried NI-DMM 3.0.4 and NI-DMM 14.  I have a PXI 4065 which works correctly.  So this is a card problem, not  a driver problem.  The questions are: 1) will a dead card still respond to the PCI ID request function and show the vendor and device ID?  2) is there any other diagnosing I can do to figure out if the card is salvageable?
(5,160 Views)
Accepted by topic author yafoteer
yafoteer,
What OS version and bitness are you using? The PXI-4060 is end-of-life and is not supported on Windows Vista or newer Windows OSes. The device OS support list for NI-DMM 14.0 may be found in the readme.
Did your PXI-4060 ever work? The yellow unknown device warning generally indicates a driver installation issue. While it is unusual for DMMs to break, it does happen, but let's rule out an unsupported OS first.
Tobias
Principal Software Engineer
Driver Software
(5,151 Views)
Call me Captain Obvious.  Well, I searched around but never found the end-of-life and OS issue.  I dug out the XP-driven legacy system and installed the card - perfect.  But it's broken in the new Win 7 system.  So even though the drivers are there, the OS is the problem.  Time for another upgrade.  Thanks
(5,140 Views)
