Digital Multimeters (DMMs) and Precision DC Sources
PXIe-4139 Output on-board relay control
About PXIe-4139 SMU:
There are two options to Switch Off Output (see attached screenshot):
  Option 1 -  by property node "Output Connected"
  Option 2 -  by "niDCPower Configure Output Enabled.vi"
According to https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OQ0SAM&l=en-BG, Option 1 disconnect (switch off) on-board relay.
What about Option 2 ???  Does "niDCPower Configure Output Enabled.vi" disconnects on-board relay as well ???
(4,451 Views)
Accepted by pgo
Hi @pgo,
Setting the Output Enabled property to “False” sets:
Output mode = Voltage
Voltage setpoint =  0V
Current limit = %2 of the current range.
It does not disconnect the output relay.
(4,432 Views)
Accepted by pgo
Thanks  ChristophersonJ !
(4,420 Views)
