Digital Multimeters (DMMs) and Precision DC Sources
PXIe-4163 current_limit_autorange seems doesn't work for low level current
Hi guys,
these days i was doing some MOSFET idVg curves sweeping using PXIe-4163, as we know, for NMOS, when Vg is about 0 volt, id is very small, saying maybe 1nA or below, it turns out to several mA when Vg gets larger and larger. So I choose current_limit_autorange to switch ranges in measuring.
I found that the current resolution is not as low as my expect. When I use the fixed current_limit_range(set to 100e-9A), I got several hundred pA to several nA, but 10e-7A for current_limit_autorange.
Message 1 of 9
(7,152 Views)
Accepted by Onezhenji
FYI - auto-ranging is not a hardware feature but a driver feature. Enabling Auto-Ranging will let the driver choose the current range to follow the current limit setting.
You need to use an advanced SMU targetted for device testing like PXIe-4137 that uses hardware-level auto-ranging.
Santhosh
Soliton Technologies
Message 2 of 9
(7,139 Views)
I do find a parameter called "autorange" in python's API of nidcpower, it seems that PXIe 4163 doesn't support this parameter.
So, 4163 can't satisfy my measurement requirements, right?
Message 3 of 9
(7,050 Views)
Is there any way I can use PXIe 4163 to achieve my measure requirements in my topic?
Message 4 of 9
(7,080 Views)
Yes, you can implement auto-ranging in software.
For every measurement,
  • Make a measurement at a higher range
  • Check measurement against the list of available ranges
  • Choose a range that suits the measurement value
  • Re-measure at the new smaller range
  • After the measurement is done, go back to the larger range
Santhosh
Message 5 of 9
(7,048 Views)
Well, it seems that I can not use sequence mode.
Message 6 of 9
(7,037 Views)
Nope, software-level auto-ranging cannot work with sequence mode as the selection of the best range happens in the application and not on hardware.
Santhosh
Message 7 of 9
(7,011 Views)
I updated nidcpower to the 2022 Q4 version, now PXIe-4163 supports auto-range. Thank u.
Message 8 of 9
(6,804 Views)
Good to know that the latest driver updates the SMU firmware to support hardware level auto-ranging
Santhosh
Message 9 of 9
(6,796 Views)
