Digital Multimeters (DMMs) and Precision DC Sources
Unable to install NI-PXI 4070 DMM driver
The installer states that the driver is "incompatible with products already installed"
I am not able to proceed because the MAX does not recognise the card & needs the driver installed before I can proceed with anything else.
I have tried un-installing NI-DAQmx & installing the NI-DMM but got the same response from the installer.
Am I missing something?
Thank you
Jonathan
(5,135 Views)
Sorry for the delay responding to this. In case you were able to solve it, it'd be interesting to hear what the issue was.
In case you weren't:
  • What OS and bitness are you installing on?
  • What NI software and versions do you have installed? You can see the list in MAX. Maybe post a screenshot.
  • What version of the NI-DMM installer are you trying to install?
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(4,880 Views)
