Digital Multimeters (DMMs) and Precision DC Sources
What does the Error Code -1074135030 mean?
Implementing device driver for DMM PXI 4070 for an in-house test program.
My workstation connects to a PXI controller with one DMM card.
Running the demo from NI-DMM for Window 2000/XP CD on my workstation is
find.
But, using the same lib file, nidmm_32.lib, as one in the demo, the
instruction
checkErr(niDMM_init(m_ResourceName, idQuery, reset, &vi)) fails and returns
Error Code = -1074135030.
I have double checked the parameters of the function:
m_ResourceName = "DAQ::5::INSTR",
idQuery = 1, and
reset = 1,
I am passing the address of vi seesion veraible to the function.
The following is the code segment I havd. It is almost the same as the
demo
found in the CD coming with the device.
When carrying out checkErr(niDMM_init(m_ResourceName, idQuery, reset, &vi))
, it jumps to the 'Error:' session, and the error code -1074135030 is shown
in
the debugger.
ViSession vi = VI_NULL
ViBoolean idQuery = VI_TRUE
ViBoolean reset = VI_TRUE
ViStatus error = VI_SUCCESS
ViInt32 measurementType = NIDMM_VAL_DC_CURRENT
ViReal64 powerlineFreq = 60
//m_PLFreq.GetItemData(m_PLFreq.GetCurSel())
ViReal64 range = 0.0200
//atof(m_RangeVal.GetBuffer(20))
ViReal64 resolution = 0.0000001
//atof(m_ResolutionVal.GetBuffer(20))
ViReal64 reading = 0.000
ViChar tempString[40]
ViChar modeStr[20]
ViChar dataStr[20]
ViChar rangeStr[20]
ViBoolean overRange = VI_FALSE
//if(mode == REAL || mode == CHECK || mode == ECHO || mode == ECHOCHECK)
/*- Initiate the DMM and create a session
/*- Configure Powerline Frequency
checkErr(niDMM_ConfigurePowerLineFrequency (vi, powerlineFreq))
/*- Configure DC Measurement
checkErr(niDMM_ConfigureMeasurement(vi, measurementType, range,
resolution))
/*- Read DC volts
checkErr(niDMM_Read (vi, NIDMM_VAL_TIME_LIMIT_AUTO, &reading))
/*- Find out if the measurement is over range ----------------------*/
niDMM_IsOverRange(vi, reading, &overRange)
/*- Display Reading
checkErr(niDMM_FormatMeasAbsolute (measurementType, range, resolution,
reading, modeStr, rangeStr, dataStr))
sprintf(tempString, "%s %s", dataStr, modeStr)
strcpy(m_res, dataStr)
Error:
if (vi)
niDMM_close(vi)
if (error < VI_SUCCESS)
ViChar errorMessage[256] = ""
/*- Get the error description
niDMM_error_message(VI_NULL, error, errorMessage)
NI Software : Measurement Studio for Visual Studio .Net version 7.1
NI Hardware : Digital Multimeters (DMMs) device PXI-4070
Driver Version : 2.5
OS : Windows 2000
(8,566 Views)
The code you posted looks fine, but I am curious about the resource name you are passing to the niDMM_init() function.  Try using the DAQmx device name of you NI PXI-4070 DMM as it appears under NI-DAQmx devices in MAX.  This will be in either the "Dev1" format or the "PXI1Slot2" format based how your chassis is identified in MAX.  Do you receive this same error if you manually enter this string as the resource name?
If this error persists, one other thing to try would be to rename your NI PXI-4070 to a particular number such as "5" instead of "Dev5" inside of NI-DAQmx devices in MAX.  From there, you can then refer to this device as "DAQ::5::INSTR".  Please refer to this KnowledgeBase entry for more information on valid resource name formats to pass to the NI-DMM driver.
If this doesn't resolve the issue, please let me know, as I want to make sure that you get this system up and running ASAP.
Have a great day!
Travis W
Message Edited by Travis W on 11-15-2006 07:21 PM
(8,554 Views)
I have the same error
The reply to this post does not make sense.  The device cannot be renamed since it is a traditional daq device.  The referenced article lists the Instrument Descriptor exactly as the post describes.  I can't get anywhere with this problem either
(8,282 Views)
Hi TAS1,
If you go into the Measurement and Automation Explorer, you can highlight the device under Traditional NI-DAQ (Legacy) Devices, right click on it and click on properties.  You can change the device number there.  The other options is to look in Measurement and Automation Explorer, take the device number and replace the 5 in DAQ::5::INSTR in your program to the current device number.  Please let me know if this does not work for you.
Message Edited by Nick F on 07-11-2007 12:43 PM
Thank You,
Nick F.
(8,264 Views)
It did not work.  I had to uninstall everything, install LabView 7.1 again then install the latest version of the complete driver package (DAQMx, DMM, MAX etc.) to get my DMM to work.
(8,243 Views)
