Digital Multimeters (DMMs) and Precision DC Sources
What version of niDCPower is required to do pulsed measurement
I need to do pulsed SMU measurements using a PCIe-4139
I have NI-DCPower v20.7 installed but the code I am using interfaces to it using a Interop file created using Measurement Studio for nidcpower 1.6
Some target systems still have older versions of NI-DCPower installed so want to limit how far I update the interop file to.
Alternatively, are the dll EntryPoints, nidcpowerConstants, and nidcpowerProperties documented anywhere so I can add only what I need?
(3,633 Views)
Accepted by markshancock
Yes, look for nidcpower.h installed on your system.
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(3,604 Views)
@kirsh - where should I look to find nidcpower.h?
Normally I look in the in the install zip but the ni-dcpower uses an online installer
(3,599 Views)
I ran the niDCPower driver install (v 20.7) on my development PC but it only installed the .NET examples
Where can I get nidcpower.h?
(3,585 Views)
Did you check under
C:\Program Files\IVI Foundation\IVI\Include\nidcpower.h
or
C:\Program Files (x86)\IVI Foundation\IVI\Include\nidcpower.h
Marcos Kirsch
NI Driver Software
(3,575 Views)
