Digital Multimeters (DMMs) and Precision DC Sources
When do you anticipate having a driver or driver library available for developing a Windows CE driver for the NI-4050
We would like to develop an application for the Oil/Gas market utilizing the NI-4050 in Compaq IPAQ devices running Windows CE.
(9,055 Views)
Currently National Instruments does not have a driver for the NI-4050 and Windows CE. If I hear any further developments on this issue I will post to this Dev Exchange entry at that time.
(9,056 Views)
I recently found that Viewpoint Systems in Rochester, NY has developed a driver for the NI-4050 for use in Windows CE. They have also worked on other NI drivers for Windows CE. You may want to contact them and find out if it is available for use.
Viewpoint Systems is one of NI's select partners and you can find a link to there website at
http://digital.ni.com/worldwide/bwcontent.nsf/web/all/850FEC49CF5B1AA786256AA700812B5F?OpenDocument&node=123000_us
Good Luck with your project.
(9,056 Views)
(9,056 Views)
NI does have C source code available to program the NI-4050 using register level programming (RLP) in Windows CE. If you are a proficient C programmer and have some experience doing RLP and/or driver level development, you can use this code to access and program the 4050 in Windows CE. Contact your local NI sales person to receive a copy of this code.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(9,055 Views)
