Digital Multimeters (DMMs) and Precision DC Sources
a sample code for PCI4070 and labview
Hi all, I am a new developer on PCI4070 and labview, now I want to read the code from the channels(voltage and current) on PCI-4070 to my labview vi and do some calculation and display. Can anyone give me a sample code as time is limited and some documents are hard to identity for the suitable scenario. Thanks~
(5,419 Views)
Accepted by NewFifty
In LabVIEW, go to Help->Find Examples.  There should be plenty of NI-DMM examples in there for you to look at.
(5,386 Views)
Thank you. Now I try to code and no DAQmx Assistant here in the LabView. I checked that the NAQ device driver has been installed (the version is 17.0), the self-test and self-calibrate both successful, but still have no  DAQmx Assistant  in the functions. Can you help me?
(5,376 Views)
PS, my labview version is 2016
(5,373 Views)
