 tadk
			tadk
			05-06-2006 04:20 PM
05-08-2006 02:30 PM
Hello tadk,
When you say that the laptop can’t find
half of the components, are these components DMM and/or SWITCH
If they are DMM and/or Switches
You can find a copy of the latest version of the drivers on our Drivers and Updates website.
The DMM driver is located under Measurement
Hardware>>Digital Multimeter and the Switches drivers is located under the
Switches link at the bottom of that same website. This should resolve the problem of the
missing
Concerning the hardware
names problem, you can change
the names of the simulated devices to be the same as the real devices
on the other machine using
Measurement and Automation Explorer (MAX). Just right click on the
simulated device
and change the name to match the name on your other system. You should
be able to run the same VI on both computers even though you have the
evaluation version installed.
Let me know if this doesn't work or if you have any questions.
Tica T
Applications Engineer
05-08-2006 07:10 PM
05-08-2006 07:24 PM
05-10-2006 11:39 AM
05-18-2006 10:43 PM
