Digital Multimeters (DMMs) and Precision DC Sources
niDMM Perform Open Cable Comp 4072 hang
I am trying to perform an open short compensation on a NI 4072 DMM
When I run the attached code my program hangs on the niDMM Perform Open Cable Comp.vi
After a long period of time I get a timeout error.
Anybody know what I am doing wrong?
Dan Shangraw, P.E.
(4,602 Views)
Hi ASTDan,
If you set your Comp type to "Open" do you still see the same behavior?
(4,561 Views)
Accepted by ASTDan
The niDMM Configure Offset Comp Ohms was causing the problem.  I removed it and open compensation works great.
Dan Shangraw, P.E.
(4,557 Views)
