Discovering and Imaging the Device
RoboRIO 1 fails to image
We are trying to format our RoboRIO 1 to the new FRC image for 2024. The Imaging Tool currently says our RoboRIO has firmware version 23.5.0f149
When we try to image it with FRC_roboRIO_2024_v2.2.zip, it fails with the following:
Error -2147220323 occurred at nisyscfg.lvlib:Format 5.3.vi:2890001
Possible reason(s): NI System Configuration: Operation timed out.
Complete call chain:
RoboRIOImagingTool.lvlib:Reconfig Device.vi
RoboRIOImagingTool.lvlib:ImageManager.vi
RoboRIOImagingTool.lvlib:ImagingToolMain.vi
Status: corrupt firmware, cannot run.
So we tried updating the firmware and got another failure.
Error -2147220323 occurred at nisyscfg.lvlib:Restart.vi:1680001
RoboRIOImagingTool.lvlib:Config Settings.vi
Subsequent attempt to format/image again was unsuccessful, with the original error indication.
(694 Views)
My name is Esteban from NI Technical Support, just to double check, have you tried formatting the roboRIO while in safe mode?
(679 Views)
Hello!  I am from team 9736, and we are having the same issue.  We have tried updating in safe mode, running the software as administrator, updating through NI MAX, tried 3 different computers, and a multitude of different usb cords to no prevail.  Any help would be greatly appreciated!
(658 Views)
@ThomasBruning
Please post a new thread for your specific issue. This helps us to keep straight which team has tried what.
(655 Views)
