Discovering and Imaging the Device
RoboRio 2 - Unrecoverable Error
We have the flashing status light of death.
We have a second RoboRio2 so this makes testing easier.
Tried all trouble shooting steps.
The SD card is good. Works in backup RoboRio 2.
Blew out the SD card slot. Removed the back and cleaned out everything.
Tried "SAFE" mode.
None of it worked. Still blinking STATUS light.
All we did was turn off the robot, put in a new battery and turn it on and the RIO was borked.
What is next steps?
(1,105 Views)
Hi AfterTen,
My name is Jessica, I'm with NI. Can you try reimaging the roboRIO SD card: roboRIO 2.0 microSD Card Imaging?
Also, have you tried a different SD card?
(1,083 Views)
Did all that. Reimaged. Tried a known working card.
Safe mode didn’t work.
blowing it out with air didn’t help.
all the trouble shooting steps.
(1,080 Views)
So is there a next step. Is this very expensive RoboRio eligible for replacement? It's been 6 days now since I last responded.
(1,036 Views)
Hi AfterTen,
I've sent you a direct message to coordinate the repair.
(1,019 Views)
