cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Change from PXI to PCI
Actually we have a Functional tester with the next PXI devices:
PXI 1010  Chasis
NI PXI-8176 Controller
NI PXI-8461 CAN Interface
NI PXI-6031E
NI PXI-6602  Counter Card
....And Now we need to change this PXI devices by using PCI cards with a conventional computer
my concern is about the functioning of the currently software once time it be with the new computer and PCI cards
my currently program will work or this plataform change involves too much software modifications.
0 kudos
Mensaje 1 de 3
4.748 Vistas
Sorry, i accidentally press enter key before finish.
the Question is:
the currently software can work with out any code modifications ?? or this change in hardware involves too much software modifications??
appreciate your help?
0 kudos
Mensaje 2 de 3
4.748 Vistas
You shouldn't have any problems porting your code unless you are using PXI specific features such as back plane synchronization etc.,
Can you post some more information about what your application is or what your code is intending to do?
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
0 kudos
Mensaje 3 de 3
4.736 Vistas
