el 05-04-2006 08:25 PM
el 05-04-2006 08:30 PM
Sorry, i accidentally press enter key before finish.
the Question is:
the currently software can work with out any code modifications ?? or this change in hardware involves too much software modifications??
appreciate your help?
el 05-05-2006 07:35 PM
You shouldn't have any problems porting your code unless you are using PXI specific features such as back plane synchronization etc.,
Can you post some more information about what your application is or what your code is intending to do?
Kalyan
