Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Compilar FPGA
Tengo un problema al tratar de compilar cualquier VI para un FPGA.
Tengo la tarjeta NEXSYS 2 que vienen con un xilinx spartan 3e-500 fg320 y me presenta 2 errores al momento de compilar, quisiera que me ayuden con alguna solucion de los erroresel primero es:
 Error code: 7
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at Error calling module generator VI: NULL
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
 +++++++++++ y el segundo es:
Ero\ror cede: 1
Internal software error occurred getting module generator VI Paths (2)
0 kudos
Mensaje 1 de 2
3.156 Vistas
Foro repetido
http://forums.ni.com/ni/board/message?board.id=6170&message.id=12140&jump=true
Carlos Pazos
Senior Product Marketing Manager
0 kudos
Mensaje 2 de 2
3.131 Vistas
