Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Custom Scales Missing
Hello.
I recently opened a VI and realized that all my custom scales were set to an intercept value of zero and a slope of zero.  I restarted the computer a couple of times but the problem persisted.  I found a couple of help topics and tried to fix the problem but I also got errors when following the procedure.  The articles I tried to follow were:
 Knowledgebase 4XQAJPBQ: Why Can't I Export My Custom Scales In the MAX Export Configuration Wizard?
KnowledgeBase 4GA9TOQA: What is the Process For Removing MAX Database Corruption?
However when following step 2 of the first article (4XQAJPBQ) i got the following errors:
Error - 50401 occurred at Property Node DAQmx System (arg 1) in GetScales.VI  and a second error in the following window
Eror 2501 Ocurred at TDMS close in Gest Scales.VI
I would appreciate any help as I need to retrieve the data from the scale configuration.
Thank you
0 kudos
Mensaje 1 de 2
3.291 Vistas
Hi mrblandon,
Where do you have set the scale? In MAX or in LabVIEW?
If you have set your scales in MAX, please check them at MAX>>My System>>Scale, do those scale are set to the proper value (slope and intercept)?
Carmen C.
0 kudos
Mensaje 2 de 2
3.267 Vistas
