cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Exporting data to ISO_EGV format
I have a problem when exporting data from data portal to ISO_EGV format.
I know that exist vbs sequences that generate the test header and the header of the channels files also.
Till this point, there is no problem.
The problem appears when saving the channels data. I always get a .nnn file with the header of the channel nnn
correctly informed, but with all data filled with NOVALUE.
In Diadem 8, a library called ISOLOAD.DLL exports correctly ISO_EGV format, but in Diadem 10, I can only find
importing data libraries for EGV_ISO.
If anyone can help me with this problem, I will be very grateful.
Thanks a lot.
0 kudos
Mensaje 1 de 3
3.702 Vistas
Hi jmpons
  Have you tried with the new datapluggins available from DIAdem 9?. You can find them in http://www.ni.com/dataplugins. In another thread they talk about them and, althought they are using DIAdem 9.1 it seems the plug-in works fine. The link to thread is
http://forums.ni.com/ni/board/message?board.id=60&message.id=3387&requireLogin=False
Hope this helps
Javier Gutiérrez
NI Spain Application Engineer
0 kudos
Mensaje 2 de 3
3.679 Vistas
Hi Javier,
Unfortunately, I had previously acceeded to the plug-ins page you told me, but only import plug-ins are available.
I can't find any plug-in to export data to ISO_EGV format.
Anyway, thank you very much.
P.S. If you discover any way to save data in ISO_EGV format, please tell me.
0 kudos
Mensaje 3 de 3
3.664 Vistas
