Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Labview doesnt show "myrio project"
I wanted to start a myrio project with myrio 1900 but labview doesnt show myrio project in one of the initial screens. My computer was not able to detect myrio 1900 but somehow in the end I could. I normally work with labview 2015 64-bits but I had to installed the 32-bit in order to run a program that I downloaded from this page https://decibel.ni.com/content/docs/DOC-40358?cid=Social-Academic-Mexico-none
It seems I installed everything related to compactRIO because I have lot of features installed that program.
I dont have installed the real time module, is it required?
Is something else required?
Thanks in advance
0 kudos
Mensaje 1 de 3
3.599 Vistas
Thanks in advance
Hola:
Necesitar el Toolkit de MyRIO: http://www.ni.com/download/labview-myrio-toolkit-2015/5518/en/
Saludos...
_________________________________________
https://aulamoisan.uva.es
0 kudos
Mensaje 2 de 3
3.592 Vistas
Hi Jazzedd,
Hope you are fine. Just as moisan said, ensure that you have already installed the LabVIEW for myRIO toolkit.
I think you have installed the LabVIEW cRIO drivers, that includes the compatibility with cRIO devices, but you also will need the LabVIEW RT, LabVIEW FPGA  if you are using the FPGA of the myRIO, and the myRIO toolkit, this includes the myRIO drivers and special API.
It is great you are using the tutorial video I created to start working with the myRIO platform.
Tell me if this problem persist after installing the suggested software.
Greetings.
Guillermo O.
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
0 kudos
Mensaje 3 de 3
3.578 Vistas
