Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Motion Assistant command window control
Hi.
My English is not so good, but I’ll try.
I was wondering, if there is possible to open M.A., load an Excel file (a list of dots) and run the program (M.A.); all of this from the command window (cmd) in windows xp pro.
If it's possible please give a hand.
If not, then would somebody please explain to me how to do it from C, Visual Basic, or LabVIEW; as it says on this page: http://www.ni.com/motion/ltb.htm: "NI Motion Assistant also exposes its patent-pending smart-contouring functionality with an API that you can call from C, Visual Basic, or LabVIEW."
Thank you
0 kudos
Mensaje 1 de 4
3.551 Vistas
Any help?
Please tell me, if it's posible to do it.
0 kudos
Mensaje 2 de 4
3.532 Vistas
Alex,
You could create a motion script with motion assistant, that would open your excel file and load de coordinates you want.
After that click Tools / Generate Code / LabView Diagram.
With that you'll create a LabView code that can be compiled to a .exe and ran from the command line.
Is that what you need?
Dario
0 kudos
Mensaje 3 de 4
3.481 Vistas
Yes, something like that was what i did.
Thanks for your help.
0 kudos
Mensaje 4 de 4
3.477 Vistas
