Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
configuration store IVI
Hola muchachos.
Alguien me puede ayudar con la configuration store.
Tengo el siguiente codigo
#include
"stdafx.h"
#import
"IviConfigServer.dll"
using
namespace IVICONFIGSERVERLib;
int
main(int argc, char* argv[])
HRESULT hr;
hr = CoInitialize(NULL);
if
(FAILED(hr))
exit(1);
IIviConfigStorePtr cs(
__uuidof(IviConfigStore));
try
// Deserialize the master configuration store.
cs->Deserialize(cs->MasterLocation);
try
// Create an empty Hardware Asset
IIviHardwareAssetPtr ha(
__uuidof(IviHardwareAsset));
//Set its properties
ha->Name = _bstr_t("Multimeter");
ha->Description = _bstr_t("Multimeter connected to the switch");
ha->IOResourceDescriptor = _bstr_t("GPIB::22::INSTR");
// Add it to the global hardware asset collection
printf("hasta aqui");
cs->HardwareAssets->Add(ha);
catch (_com_error e) {
printf("Add HardwareAsset failed.\n");
printf("Error description is: %s\n",(
char*)e.Description());
getchar();
try
// Create an empty DriverSession
IIviDriverSessionPtr ds(
__uuidof(IviDriverSession));
// Set its properties
ds->Name = _bstr_t("Crack");
ds->Description = _bstr_t("DriverSession for the system multimeter");
ds->Cache =
true;
ds->InterchangeCheck =
false;
ds->QueryInstrStatus =
false;
ds->RangeCheck =
true;
ds->RecordCoercions =
false;
ds->Simulate =
false;
ds->DriverSetup = _bstr_t("");
// Add the HardwareAsset reference to the Session
ds->HardwareAsset = cs->HardwareAssets->Item["Crack"];
// Add the SoftwareModule reference to the Session.
ds->SoftwareModule = cs->SoftwareModules->Item["Crack"];
// Add it to the global driver session collection
cs->DriverSessions->Add(ds);
printf("Add DriverSession failed.\n");
getchar();
try
// Create the Logical Name
IIviLogicalNamePtr ln(
__uuidof(IviLogicalName));
ln->Name = _bstr_t("DMM");
ln->Description = _bstr_t("The name used in the test program");
ln->Session = cs->Sessions->Item["Crack"];
// Add it to the global logical name collection
cs->LogicalNames->Add(ln);
printf("Add LogicalName failed.\n");
getchar();
// Overwrite the master with the modified configuration store
try
cs->Serialize(cs->MasterLocation);
printf("Serialize failed.\n");
getchar();
printf("Deserialize failed.\n");
getchar();
CoUninitialize();
return
0;
El resultado que me da por pantalla es:
hasta aquiAdd HardwareAsset failed.
Error description is: IviConfigServer.IviHardwareAssetCollection.1: Add failed.
 Multimeter already exists in the collection or it has already been owned by ano
ther collection.
hasta aquiAdd DriverSession failed.
Error description is: IviConfigServer.IviSoftwareModuleCollection.1: get_Item fa
iled.  Crack does not exist in the collection.
Error description is: IviConfigServer.IviSessionCollection.1: get_Item failed.
Realmente no tengo ningun intrumento aun en red: NO se si ese puede ser el problema, aunque entiendo que para el config server deberia de dar igual ya que es un paso previo a la conexion.
Otra duda que tengo es que es exactamente el SoftwareModule, me refiero a si es algo dependiente de cada instrumento o es algo que "pone" el config server
Espero vuestra ayuda y si m podeis aclarar si ustedes conseguis que este software funcione decidme como porfavor..
Saludos y gracias
0 kudos
Mensaje 1 de 1
4.001 Vistas
