Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
SImulation toolkit -RT
Hello everybody,
I’ have a problem using the simulation toolkit in a real time target.
First of all I have translated a simulink controler to LabVIEW using the sim. toolkit.
The controler have been simulated outside the real time project and everything runs properly
I have followed the tutorial of modelling and then set the period of the loop configuration to 0 and place a "wait until next" ms multiple of the time step on the simulation diagram. These simulation file contains some subVIs.
The problem appears when I try to introduce this VI into the RT- Project:
1) I open a RT-Project
2) In the Project Explorer I add the "simulation VI" file into the RT Target.
When I try to open the VI added, the program try to compile some of the subVI of the file but without successful, a program error arrives.
Thank you so much in advance,
Jaione
0 kudos
Mensaje 1 de 4
3.180 Vistas
Hi Jaione,
what errors do you get? Can you attach some screeshots?
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
0 kudos
Mensaje 2 de 4
3.154 Vistas
Hi RMathews,
The problem is that there are no errors in the screen. Then I have no idea what happen.
The simulation block diagram has some subsystems, I insert all of them independently inside a simulation loop in the real time project and no error appears. But when I try to put all of them together, the program crash, I mean, Labview close itself.
Do you have some idea what happen?
I know is difficult to solve because there are no error information.
Thank you so much.
Cheers,
Jaione
Mensaje editado por Jaione
0 kudos
Mensaje 3 de 4
3.143 Vistas
with the Dr. Watson error report you should see something.
Here you have a link:
http://ae/operations/ae/public.nsf/webPreview/D1BBDF79E090E0C586256AF5007C1CCE?OpenDocument
Try this and post the results.
RMathews
Ramona Lombardo
0 kudos
Mensaje 4 de 4
3.140 Vistas
