Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
anemómetro
hola ,saludos ,lo probé pero no puedo ver los datos en Labview,
Cargo este programa de Arduino :
#define uint  unsigned int
#define ulong unsigned long
#define PIN_ANEMOMETER  2     // Digital 2
#define PIN_VANE        5     // Analog 5
// How often we want to calculate wind speed or direction
#define MSECS_CALC_WIND_SPEED 5000
#define MSECS_CALC_WIND_DIR   5000
volatile int numRevsAnemometer = 0; // Incremented in the interrupt
ulong nextCalcSpeed;                // When we next calc the wind speed
ulong nextCalcDir;                  // When we next calc the direction
ulong time;                         // Millis() at each start of loop().
// ADC readings:
#define NUMDIRS 8
ulong   adc[NUMDIRS] = {26, 45, 77, 118, 161, 196, 220, 256};
// These directions match 1-for-1 with the values in adc, but
// will have to be adjusted as noted above. Modify 'dirOffset'
// to which direction is 'away' (it's West here).
char *strVals[NUMDIRS] = {"W","NW","N","SW","NE","S","SE","E"};
byte dirOffset=0;
// Initialize
void setup() {
   Serial.begin(9600);
   pinMode(PIN_ANEMOMETER, INPUT);
   digitalWrite(PIN_ANEMOMETER, HIGH);
   attachInterrupt(0, countAnemometer, FALLING);
   nextCalcSpeed = millis() + MSECS_CALC_WIND_SPEED;
   nextCalcDir   = millis() + MSECS_CALC_WIND_DIR;
// Main loop.
void loop() {
   time = millis();
   if (time >= nextCalcSpeed) {
      calcWindSpeed();
      nextCalcSpeed = time + MSECS_CALC_WIND_SPEED;
   if (time >= nextCalcDir) {
      calcWindDir();
      nextCalcDir = time + MSECS_CALC_WIND_DIR;
// Interrupt handler for anemometer. Called each time the reed
// switch triggers (one revolution).
void countAnemometer() {
   numRevsAnemometer++;
// Find vane direction.
void calcWindDir() {
   int val;
   byte x, reading;
   val = analogRead(PIN_VANE);
   val >>=2;                        // Shift to 255 range
   reading = val;
   // Look the reading up in directions table. Find the first value
   // that's >= to what we got.
   for (x=0; x<NUMDIRS; x++) {
      if (adc[x] >= reading)
         break;
   //Serial.println(reading, DEC);
   x = (x + dirOffset) % 8;   // Adjust for orientation
   Serial.print("  Dir: ");
   Serial.println(strVals[x]);
// Calculate the wind speed, and display it (or log it, whatever).
// 1 rev/sec = 1.492 mph
void calcWindSpeed() {
   int x, iSpeed;
   // This will produce mph * 10
   // (didn't calc right when done as one statement)
   long speed = 14920;
   speed *= numRevsAnemometer;
   speed /= MSECS_CALC_WIND_SPEED;
   iSpeed = speed;         // Need this for formatting below
   Serial.print("Wind speed: ");
   x = iSpeed / 10;
   Serial.print(x);
   Serial.print('.');
   x = iSpeed % 10;
   Serial.print(x);
   numRevsAnemometer = 0;        // Reset counter
2.- DESPUES CARGO EL LIV DE LABVIEW.
3.- selecciono el puerto
no se si el procedimiento es el adecuado,
Y nuevamente gracias por tu ayuda.
0 kudos
Mensaje 11 de 16
2.872 Vistas
Hola celsotf,
         La velocidad la tienes en 9600 (cuando pones Serial.begin(9600); ) y en el VI esta en 115200 (baud rate), tienes que seleccionar el puerto antes de darle para que se ejecute, te adjunto nuevamente el mismo VI con el cambio en la velocidad y unos indicadores adicionales para que muestre si esta ocurriendo algún error y que efectivamente se estan recibiendo los datos.
Saludos,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
0 kudos
Mensaje 12 de 16
2.868 Vistas
Buenas noches , un saludos ya  probé de nuevo pero sin ningún resultado aquí te dejo una imagen de la pantalla espero que te pueda servir
Configure el puerto , y antes de darle a RUN pongo el puerto, no se si hay que cargar el toolki LIFA _Base
Un saludo y gracias por tu tiempo ,estoy muy agradecido saludos.
0 kudos
Mensaje 13 de 16
2.866 Vistas
Sigo sinpoder resolver el problema si alguien me puede ayudar estaria muy agradecido.
0 kudos
Mensaje 14 de 16
2.496 Vistas
Excelente aporte Inge!!!!   Gracias!!!!
0 kudos
Mensaje 15 de 16
1.447 Vistas
Hola amigo buen dia, si pudiste conectar el anenometro con el arduino?
0 kudos
Mensaje 16 de 16
1.265 Vistas
