Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
redpitaya-Synchronised one pulse signal generation and acquisition
Hi, I'm new working with redpitaya and labview.
I' ve been trying to get the example " Synchronised one pulse signal generation and acquisition" with labview worked. But I have some problems.
Fisly, when I downloaded it, some of the varibles where the wrong type, so connection couldn't be done ( 1-picture). So I use a converter block ( from string to number) in order to solve this problem, as it wan't working I changed directly two of the inputs from string to number and I kept the conversion of the rest of variables string (2-picture).
I wasn't getting any error, but the example wasn't working properly. When I play run, it only resgisted noise, but no the signal It was creating (3- picture). I change the paramethers ( chanel I was using, amplitude, frecuency, the form of the signal itself)
To check that the wire and the RF input and output was OK I tried to modify the signal, putting it on my hand, and the noise signal change, but It was still noise (4-picture). I have tried every input and output, but I got always the same signal: noise.
To conclude: I can't make this example works.
Futhermore, I have a question about this example: How can I change fron input 1 to input 2 and from output 1 to output 2, because I only see the option chanel 1 and chanel 2, but it doesn't say which combination of input and output is.
If someone got the same problem, and how did you solve it?
Thanks in advance!!
0 kudos
Mensaje 1 de 1
3.428 Vistas
