el 01-10-2012 04:49 PM
Hi Flavio83
I was searching and I look that if you make a right click in the waveform chart you can go down in the menu where it says Chart History Length and you can configure the size of the buffer from the graphic, also I was thinking that maybe you have a race condition because all you variables, to see some information about this you can check in this link, also here is tutorial, a video and a forum where there's also a race condition.
Best Regards
Julio Mena
el 01-12-2012 01:58 PM
Hi Julio
I send you and example similar to the project I'm doing. In the project you'll find a motor VI (prueba.vi) this VI writes on the shared variable and the other VI called prueba historicos.vi I used to access it throught a web page. When I had about 0.5 day data saved (in Citadel), prueba historicos.vi runs witohut a problem for 4 hour time interval, but when I open its web page Labview closes. This also happened with the application (executable)
I'll be looking for another way to see historical data wihtout using web server.
FLAVIO
el 01-20-2012 03:56 PM
Hi Falvio83
I have seen your project and I'm have some doubts. What is the error that labVIEW show when it close? Your VI prueba historicos.vi is running before you open the web page? What happen when you open the web page before the 4 hours? Do you run both VI's at the same time or you run one and after a while you run the other one? I notice that you speak spanish and If you feel more comfortable explaining on spanish feel free to do it. I'm from Mexico
Best Regards
Julio Mena
