Distributed Control & Automation Framework (DCAF)
"NI SCAN ENGINE" files missing in the DCAF example
Hi
  My labview was 2017 64bit. when i download DCAF core in VIPM and all the installment was finished. When i open the DCAF example "Temp controller Example" . The "NI SCAN Engine"can not be found. is there any way that i could download the NI SCAN Engine separately that i could select this folder manually.
(3,658 Views)
Accepted by Danielweng
Hello!
The Scan Engine is installed with the LabVIEW Real-Time Module, which only supports 32-but LabVIEW.  You’ll need to use 32-bit LabVIEW with the LabVIEW Real-Time Module installedif you want to use this functionality.  If you use the simulated temperature controller, you can run the example without needing the Scan Engine.
Cheers,
Matt Pollock
(3,655 Views)
