Driver Development Kit (DDK)
AI scaling range
I have a issue with the AI scaling with a NI6229 Device.
Set the Input to 0.0V, then is the return value of aiPolynomialScaler(..) -10.63V and if the input 10V, i get -0.63V.
And this will continue linearly:
Input         Output
-10.0V ->  0.63V
  -5.0V ->  5.63V
   0.0V ->  10.63V
   5.0V ->  -5.63V
 10.0V -> -0.63V
Is there a adjustment for a accurate conversion or I have to do my own conversion scaling?
The Parameter "gain" for aiConfiguration(..) is 0 (input range from -10V to 10V).
The Inputsource is a AO-Channel.
 Kind regards,
Heiko Mayer
(8,394 Views)
Accepted by topic author HeikoM
Hi Heiko,
I overlooked the changes you made to the example to get the 622x devices to work, and there's a mistake in your configuration: M Series boards (all 622x, all 625x, all 628x) do not support unipolar AI ranges [1]. In your call to aiConfigureChannel(), you need to use tMSeries::tAI_Config_FIFO_Data::kAI_Config_PolarityBipolar. Another thread in this sub-forum also points this out [2].
[1] M Series Manual, section 4-3, page 49
https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/m-series-user-manu...
[2] register guide for 6220, 6224
https://forums.ni.com/t5/Driver-Development-Kit-DDK/register-guide-for-6220-6224/m-p/758884?query.id...
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(8,384 Views)
Hello Joe F.,
that´s it!
Thanks a lot!
Kind regards,
Heiko
(8,367 Views)
