Driver Development Kit (DDK)
NI driver for Sonix STR8100 D card
I have Sonix STR8100 that works with DOS-based digital oscilloscope
software and want to upgrate to a driver for LabVIEW.
(6,884 Views)
The windows hardware driver for this card would only be available from the vendor. If it is a dll, then you can use the LabVIEW Call Library Function Node to access the dll.
p.s. You posted to the wrong board. This board is for the NI DDK (Driver Development Kit) which allows you to write your own driver for an NI DAQ board.
(6,882 Views)
